F150 Pat
Today, cold out, I put the window up with the auto up and it goes up, stops and came back down to about a third open. Did it every time. If I bring it up slowly it stays up and tight. Motor?
Could you explain or post a link for other members who come across the same problem?Found the answer on YouTube. Should of looked there first. Thanks
Window bounce back feature. You have to reinitialize the window switches and wait 48hrs. Same thing happens when you put window vent shades in the track. Window goes up, feels something it shouldn’t, and comes back down to 1/3 showing. Helps save kids arms and necks from being caught.Could you explain or post a link for other members who come across the same problem?
Should not need to do this, if it works just fine when warmer. This is to reset it, and relearn.Window bounce back feature. You have to reinitialize the window switches and wait 48hrs. Same thing happens when you put window vent shades in the track. Window goes up, feels something it shouldn’t, and comes back down to 1/3 showing. Helps save kids arms and necks from being caught.
Shut the door, pull on the auto up switch until window is all the way up and hold for another 3 seconds. Let it sit 48hrs without using the window switch.
GreatShould not need to do this, if it works just fine when warmer. This is to reset it, and relearn.
