I get an initial clunk, clunk, clunk sound below 10 mph, but then it goes away. Above 65 mph I get a loud humming sound and above 75 it is extremely loud. If you have ever been in a humvee it sounds like the cooling fan of a humvee. The sound is there even when I am in neutral at those speeds. it stays there while in 4 high too.
I changed both the front and rear differential fluids last week and rotated the tires. . The front drive shaft feels tight as does the CV joints. There is a small amount of play in the front diff. bearing on the drivers side though. Wheels were aligned two weeks ago too.
I figured I would play the elimination game - take the CV joint out and check, then the drive shaft, then swap out a front wheel bearing, etc...
