Dual Exhuast
BakerEdition
EF Chaplain
Does....let me rephrase that....who has some Expo pics with dual exhaust? I have seen the magna flow system with one muffler and 2 tail pipes...but was wondering if I have the leave the cats and the Y pipe can I eliminate the very last cat and go into a two muffler and 2 TP's? will eliminating that last cat trip any codes?:hmm:
walnuts4x4
Watertown, NY
I have a "rear cat delete" just pipe... cut the factory Y and ran true duals to Flowmaster 40s...
TRUE DUALS
FLOWMASTER 40S
REAR EXIT
sorry no vid need to make one...
2000eb
Nuts why not just di/do would have been cheaper
Thermo
technical advisor
Baker, I have a true dual exhaust setup on my truck. I'm running 2.5" pipes all the way. I had the Y- pipe removed and then both pipes run to a single muffler (DI/DO). I then have 2 pipes coming out the passenger side.
Yes, you can run 2 mufflers, but I would recommend having some sort of cross over pipe before the mufflers to help equalize the exhaust flows. It is preferable to use an X-Pipe as this helps to scavenge exhaust from the tube that is not flowing at that moment (keep in mind that only 1 cylinder is exhausting at any given time), so, you can create a slight vacuum at the exhaust valve so as it opens, it will be that much larger of a differential and help pull the exhaust out that much faster. Less exhaust left over, the more fresh air that can be pushed in, therefore more power. Will the truck run without a cross over pipe or an H-Pipe. Of course. But, for the little bit extra in dollars, you can get a bit more power.
As for removing the cats, this is a double edge sword. The big trick is keeping atleast some sort of cat between the two O2 sensors. The computer is looking for a different in exhaust gas levels between the two sensors. So, as long as the remaining cat is doing its job adequately, it won't be an issue. The other thing to consider is whether your area is doing emissions testing or not. If they aren't, then you are good. But, if they are, you have to make sure that the installed cat is working pretty good or the vehicle can fail the emmissions testing due to the cat not converting enough of the gases.
so, the answer isn't a black and white yes/no answer. There is some situational things that need to be considered.
BakerEdition
BakerEdition
EF Chaplain
Thank you much for the derails...its hard to get to straight with that fuel tank sitting there...
toms89
technical advisor
MD
I have custom 3" dual exhaust with high flow cats to a dual in and out magnaflow muffler with built in x-pipe. It changes over to 2 1/2" tailpipes after muffler. I also had resonators (small glass packs basically) installed after the muffler. Its still too damn loud for me. Very, very deep exhaust note.
JTKustoms
Boston
picture.php
4" slash cut stainless tips. this is an old pic and it now has no muffler but the tips are still the same
NC-Expy
Apex, NC
I was going to do a true dual set up but I think for what it's worth I'll go with a no muffler set up instead.
The guy at my exhaust shop said he'd buy my factory y pipe and muffler so I'll get it done for pretty cheap.
BakerEdition
BakerEdition
EF Chaplain
How will you work around the cats and O2 sensor, Check Engine light..etc...is there a value to that Y pipe?
walnuts4x4
Watertown, NY
as long as your front cats are still there or you get some high-flow cats it wont trip the CEL... at least I haven't had any problems
Soldier777
ok here are some pics of the set up... i just rushed out this morning. will get more and a vid soon
Soldier777
wow I just realized how those did not come out very good. i will take my time tonight and get some better pics
toms89
technical advisor
MD
Theres also a ********* hole where your license plate goes ?! :shrug:
panda24619
San Diego
WOW! haha
all this talk about dual exhaust makes me want to get one. but i think im gonna keep my single 3". i need to cut it and have a shop put a dump on it.
