ROCKSBITE
i did all the research and saw what everyone is running. everything from 2 fans in an expensive shroud to 2 fans attached to the radiator..
well i pick the cheeper way. i bought 2 e fans and all the controls. the thermostat screws in to the top of the manifold. the wiring is all corect. but on the hottest day of the year when i installed them i couldnt get the truck to not over heat. the fans turned on and pulled air the correct way.
so i tore it all out went back to stock and threw it all in a box.. well now i want to up size tires and think the e fans will help give me a little more power.
i havnt found a post or bit of info leading to believe that 2 fans cant cool this motor with out the shroud! so im thinking either the thermostat is bad or i may have a clogged radiator. BUT i have NO issues with the stock fan!
