Ecoboost Spark Plug Change
Motorcity muscle
Motorcity
What post in this thread lead you to believe the Ecoboost is "still" having problems? When has the Ecoboost had any problems at all? So its better to change the plugs sooner than later. I'd hardly call that a problem. As said earlier forced induction is going to be harder on plugs then NA, its just a fact.
My understanding that the eco's carbon up and has to be disassembled to correct, FTE has several post on these issues.
getnbzi
maryland
haven't even looked under the engine cover how easy is it to get it off? I have a miss at idle too. 47KKKK
East-TN
Air Force
TN
Very easy to remove...lift up and out...a couple of clips and a ‘retainer’ hold it in place. Takes about 10 seconds to remove.
07xln
Dallas
There’s guys on here approaching 100k mikes. There are guys on the F150 forums approaching double that. They seem to still be going strong. While carbon build up seems to be more premature in direct injection motors, it’s hardly caused issues for the ecoboost and been directly related to any problems. The 18 and up models take care of this with port and direct injection.
Muddy Bean
I just love how many guys with 5.4 Expeditions come on here and make assumptions about the 3.5’s. It’s like every week someone who doesn’t own an ecoboost dogs on it. I sound like a broken record, but there are several documented ecoboosts in F150’s they have gone 300,000 trouble free miles. No catch can, no drama. This thread is about spark plugs, how doth it drift...
It goes both ways, can’t count how many times someone who’s never owned a 5.0 or 5.4L say how they “lack torque” and “aren’t reliable” or that they “can’t tow” meanwhile they are on their first ford and have never even driven a Ford V8. Most of these being ecoboost owners. I can provide Many threads documenting the modular V8 going 500,000 miles for all those who say they “aren’t reliable”.
cmiles97
Tampa, FL
You can add an oil catch can but have to drain it every so often or clean the intake valves with a spray to remove carbon which is shown below. If there are intake issues with ecoboost engines, they will be exposed. The service companies I have worked for all use Ford as their full sized vans with ecoboost motors, now. Most of these guys skip regular service, leave the vans running all day & beat the heck out of them. The plugs won't get changed until it says so in the service manual. They'll never clean the intakes or add oil catch cans. What about the ecoboost sports being used by the police? I also forgot to mention all the sales cars are Ford Fusions or Escapes with turbo engines. Any inherent problems will show up, if they exist.
jeff kushner
North of Annapolis
As far as the gap setting goes....the iggy system, like most in use today regardless of actual type, produces a very hot spark, enough to easily jump a .6 to 1mm gap. (The "snap" from a 1mm gapped plug is impressive to watch)
OK, that stated, we found at the track that a close gap produced the smoothest running but the wider gap produced the most HP BUT the delta was very small. You would never notice the difference in power in street driving so to set them initially on the close side, knowing that they constantly "open" over time, has made the most sense for 40 years, even before the higher power iggy systems came into general use...
jeff
07xln
Dallas
That's weird because I haven't seen anybody on this forum especially myself dog on the 5.4. Ive said numerous times the Eco makes more power and torque and is on paper a better motor. I'd hardly call that dogging on it. Now the 4.6 that's a different story. Those flat out suck but still reliable. I don't think it goes both ways. People dog on the 3.5 way more, yourself included. You used to bad mouth it all the time on here
Motorcity muscle
Motorcity
Just stating what was told to me by a ford engineer, avoided eco with my wife/s explorer. Not knocking the eco just trying to hear real world info, have had eight econoline's over the years with 300 sixes and the 5.4's, all good. Not sure where your assumptions are from but I am a solid blue oval guy.
07xln
Dallas
Your firs post was “so Ford is still having problems with the Ecoboost, thought they would have figured it out by now”
That’s an assumption
Muddy Bean
My friend in New Jersey who has been a Ford engineer since I was 7 years old recently spent a bunch of time with me on the phone going over body schematics so we could determine where mice were entering my truck. He successfully pointed me to the likeliest place and he was right. He loves and own the ecoboost and considers it one of Ford’s best motors in the lineup. So I guess even Ford engineers can’t agree on this. If that’s the case, then we are all outta luck.
99WhiteC5Coupe
Where were mice likely entering your truck?
Muddy Bean
Behind the tail light there are pressure equalizing rubber flaps over louvered vents. One of the flaps was pushed up and out of the way and there were paper towel shreddings there. I put heavy screen mesh there and not a single mouse since. After catching 6 over the course of a couple weeks.
Budman55
