Electric fans loud
Sunflowergirl
Mars
Same with my 2015 Expedition Limited 4x4, purchased new - very loud, roaring fans. I returned it to the dealer and was told it was normal. There is no mention in the vehicle owner’s manual of excessive noise from the fans under certain conditions.
Well Thts like 9/9 on someone having it and being told it’s normal. We r beating a dead horse here guys
07navi
Mt.Shasta California
The manual is not going to say anything derogatory that makes a vehicle less appealing.
Also; It's normal! :33:
JacobMcL
Deer Park, WA
I have had a 2015 for 120k miles that I bought new. I also service several other for family. Fans that are on high that makes people comment are NOT normal. In my ownership two things have caused high fans- the AC system needs servicing like low charge, pressure sensor, compressor, expansion valve. Or a coolant system has an issue like aftermarket water pump, thermostat failure, coolant level ect. I have experienced issues from both Systems. Under normal driving the fans should not be on high. It has been triple digits lately and my fans have not gone to high speed.
inmanlanier
Florida
OGBobbyjohnson - we're in Florida as well. We've had our 2012 for about 7 years now and noticed the 'loud' fan mode for the first time about when you posted as well. I noted first, then mentioned to my wife. Sure enough, the next hot day she started up there it was. Once we get moving, however it stops and typically will not resume unless the vehicle sits at idle for an extended period.
I concluded that it's just another cooling mode they enable for when the ambient temp is up there. Not of concern IMHO.
Sunflowergirl
Mars
Are you trying to suggest that you tune is actively working the thermostat?
The tune does not Work the tstat. But it dies tell my fans to kick on earlier than stock setting. I don’t see above 190 anymore EVER. Stock id see 225-230
inmanlanier
Florida
Got it - not 'open early (i.e. thermostat), but 'turn fans on sooner'. Every 5.4 I've looked at has a traditional thermostat housing which means its the classic passive design (thermally actuated spring).
Sunflowergirl
Mars
Oh no it opens earlier too
inmanlanier
Florida
Yes, the thermostat opens earlier by it's 170 design, not because some other device makes it do so. I meant it opens at 170 regardless of your tune. Active valves are valves which have an external impetus to change the position, passive means you don't have to take action, it will do it on it's own (like a check valve). The spring in the thermostat is what opens it - it's designed to expand and contract (push or pull the obturator) open and closed on or about the setpoint.
Sunflowergirl
Mars
Correct, we are on same page now.
Jeremygsu
Florida
Big difference between Washington weather and Florida. I notice they tend to run louder on really hot days and when it's been sitting in the heat all day. Then they seem to fire up right away when remote started.
Sunflowergirl
Mars
Totally normal
thenaaks
Sparta TN
When you remote start on a hot day, the AC is trying to cool it down as much as possible as quickly as possible. That requires air movement across the fins of the AC condenser. That's why the fans come on in the High setting.
Sent from my SM-G960U using Tapatalk
NickC31
Dallas,Tx
My are really loud. I think it is just a poor design. I've had to shut down the engine at a drive through.
Sent from my moto g(7) play using Tapatalk
I have 17 expedition it is really loud when ac is on also. All mechanics say same thing kt is normal when I know it is not. I have seen a dozen or so people on YouTube with different vehicles change out thermostat and that solved their issues. Have you heard anything similar to that?
JasonH
Houston, TX
I have a 17 Expedition as well. I recently replaced the water pump and thermostat. It's still loud, sounds like a jet engine. My water pump was failing. I don't think the noise stems from any mechanical defect...the engine just needs a lot of airflow to cool the large interior. Even on a 95+ degree day, the interior gets cool within 10 minutes.
