I have an 03 expo, The problem I am runnin into is my door locks do not have power! The radio fuse is right below the door locks, and that obviosusly has power cause that works! The radio will not shut off when the doors open, i do not have a door ajar light, and the dome lights shut off! I have checked the fuse to see if that is blown and the fuse is good. I was told to check the wires going through the door and i seen no obvious problemws with the wiring although i did not look very good, but i did pull the boots off but did not slide the boot all the way to the right because i ran out tof time please help !
