prorocke
I own a '98 with the 4.6L engine. I keep getting a check engine light with engine trouble codes of PO171 and PO174, which I believe are bank #1 and bank #2 running a lean fuel mixture. I also have a shuddering /rattling sound that is alot like spark knock. I only here this knocking whenever the engine is put under a load, such as going up an incline.
Are these problems related?
I have already replaced all four Oxygen Sensors, EGR valve, plugs and plug wires, PCV valve and Fuel filter.
I am suspect of the MAF sensor and/or the coil packs, or maybe even an exhaust leak somewhere.
Any suggestions?
-prorocke
Any suggestions?
-prorocke
