wingrg
Hi i know that is very dificult to diagnost a engine noise but let me try, first 2003 Ford Expi 4x4 EB w/ 105000 miles, well in the morning theres a lot of noise when you turn on the engine but disapears in a few seconds, next some times you can hear the engine like when you use cheap fuel you can hear the pistons under woot i'm not a mechanical guru so sorry about the terms i use, but i dont know if its a belt tensioner symptom or in a worse case a timing belt issue, actions dont to try correct the problem: oil change to Gastrol synthec, oil filter change, use octane boost and metal lube use without results, im just scare of the second because this my only vehicle to get to work any help or advise going to be apreciate. Thanks!
