Hey everyone, kinda wishing my first post was more of a hello but I'm here for some help. I've owned my 2008 EB Expedition for about 3 years now. Last year it started having some issues, misfires in a couple cylinders. After replacing the coil packs on all 8 cylinders and the spark plugs on the failing cylinders and cleaning the intake throttle body I ended up getting the cam phasers replaced. Since then it's been much better but the check engine light came back on for a cam position sensor. I replaced both, the one reported failing was the drivers side and was covered with oil when I pulled it.
I've uploaded a couple videos, one before and one after doing some more cleaning to see if that would help but it's just not as quite as it used to be and the check engine light still shows an issue with the cam position sensor after being cleared.
Any thoughts on what else I could check?
