Engine/tranny shutters/bucks
PaulT
new york
2006 Ford Expedition
Engine/tranny shutters/bucks, it seems to happen when traveling at constant speed, low RPM (40-45 mph, 60-65 mph, etc) and need to accelerate. Almost feels like tranny trying to down shift or searching for correct gear (similar feeling if I was driving a manual and in wrong gear). Did some web searching and consensus seems to be the plugs and COP not the tranny.
Any help would be appreciated. And of course the plugs have are over 100K miles on them so the other issue is mechanic trying to remove them with out breaking electrode shield (TSB 08-7-6)
Juan Alvarez
Conroe, TX
I have the a very similar issue. Mine shutters at 40-50 mph during low level acceleration. If I do high level acceleration it will not shutter. It doesn’t seem to affect it much as the RPM stays somewhat constant and the truck keeps on accelerating with no issue. After that it doesn’t shutter past 50 mph. My 1999 5.4 Eddie Bauer only has 87,000 original miles and I have changed out the spark plugs .Hope someone with experience helps us out.
Adieu
SoCal
Also, it does not do it if I turn overdrive off
Tranny, then
Check and refill fluid, see if that helps.... faaaar cheaper than other more drastic tranny services
deweysmith
Montreal, QC
You could also change the fluid, but that runs the risk of making it mostly undriveable if your transmission is that far gone.
expresspedition
