GaryB
This issue is driving me nuts...
Once in a great while, I can hear a faint tick on startup that goes away on the driver's side. Not all cold startups though. Can't find any cracks in the Left manifold. Had it in the garage today doing a power steering flush. (Turns out you can use the rack alone to push the old fluid out, without the motor on, which was stressfree).
When I let it idle, I could definitely smell it on the driver's side under the hood, not on the passenger side. I smell it mostly in the cab....a whiff here or there while driving.
I actually just went as far as checking the spark plugs I put in a few weeks back to make sure they're tight....they are. What else should I be checking?
