k9education
- Joined
- Nov 12, 2014
- Posts
- 397
- Reaction score
- 47
I wouldnt say that a full sized truck is for spirited driving, but like the above poaster Ill agree that the truck does very well for what it is. I whop it hard soemtimes and it does well, but far from designed for spirited driving. Honestly Id say it should handle most of what the mountaineer can in the twisties, but again not the design goal and really just a way to eat up tires.
Honestly if you want bigger but also for such driving Id recomend a crossover or even something like the flex. Almost the same room inside (not as tall inside Id think) but built like a car and not a body on frame truck. Just my $.02 and good luck with your decision.
Ive driven both on Test drives and can say the el is not really for Spirit drivin, but is more than capable for everyday driving. The el is softer the the regular length so the handling trade off goes To a more serene ride. I did take the regular up a on ramp at 80 and was surprised it was just as capable as my 15 mazda 6, albeit more top heavy
I don't have an EL, or an Expy for that matter.... but I will say there is a big difference between my 05 Navi on the stock 285/65 18"s and on the 305/45 22"s. Turn in is noticeably better as well as overall grip. The truck still leans a lot on corners, I will end up upgrading anti sway bars to see if that helps. Overall it does will for a 6000lb truck.
The expy is a really good choice, i guess it rele depends on your needs. If i were to Choose it would most definitely be the el just because its the best riding suv and quietest on THe road, well maybe except the newer ones and newer lux suvs, and i wouldnt need an suv to drive like a sports car. The extra space is way more than useful. The 17s have a heavier steering than the bigger wheels and have a less shaky ride, i would try all wheel sizes, the 20s may feel a tad lighter on its feet but will be less absorbent.
Not to burst your bubble but asking for a 6,000 lb SUV to be spirited is a bit of a reach. Either will handle significantly better than your current Mercury. I've owned or had as company vehicles all 3 you are talking about. I had a 1999 or 2000 Ford Explorer V-8 AWD but even with good tires and shocks the handling was marginal at best (on par for what it was and what was the standard for the time). My company issued 2006 GMC 2500 actually handled better in every aspect than my personal Explorer. Eventually they moved me to a new 2008 Expedition EL 4x4. It drove much better than the 2500 Yukon but with a lot less payload capacity. I had the stock 18s with Michelin LTX AT2s and I would say handling was very similar to the 2500 Yukon (the quadrasteer helped the yukon greatly in corners). At the end of the day the expedition's handling isn't even close to sporty or spirited. Car and Driver just tested a 2015 Expedition even with the CCV and 22s it could only muster a dismal .78Gs on the skid pad and 39.2 MPH in the slalom. This is right in the mix with the likes of the Kia Sedona, Toyota Sienna and Honda Odyssey (yawn). Combine that with mid 16 second quarter miles and it does what it's supposed to haul a lot of crap slow and steady.
If you go back and look (it's hard to find good data on the 2000 explorer or mountaineer) but a 2002 Explorer (significantly improved) only mustered a .66 on the skidpad and the 1991 Explorer pulled in a .64.
As noted before tire wheel combos will make a slight difference but so does the trailering package. If you select the trailering package no matter what wheel tire combo the truck ships with you get the stiffest factory swaybar. There are also aftermarket bars available to help stiffen up the chassis as well.
Lastly you need to realize that no matter what tire wheel combo you select the tires will be crap. They put P metric tires on their to keep their CAFE numbers up as well as improve the perceived ride quality. I would plan on installing a set of nice sticky LT truck tires if you want to really improve things.
