Muddy Bean
We’ve been on an extended tour all over the US this year pulling our 23 foot camper. Truck has been running perfectly until yesterday when it basically ran terrible and finally just lost power and I could only go around 60mph under full throttle. I assumed I had a bad coil pack or spark plug, so I pulled into an auto part stores off the interstate today and bought motorcraft plugs and a single coil pack. I checked my codes and had misfire of cylinder 1, cylinder 4, and cylinder 6 and then a multiple random cylinder misfire code too. I thought that was odd. I replaced the plugs on all cylinders, and that didn’t fix the issue. I then replaced the coil pack on cylinder 4 since that was the code that was initially thrown and at one point during my testing was the only code thrown for a bit. No change. Still ran terrible, still threw same exact set of codes.
Finally I got my drill out and a 1/16th bit and poked a weep hole in the appropriate spot in my intercooler. Oily wetness came out....took it for a test run, and finally it ran right again.
For some reason I thought by 2015 they had redesigned the air cooler to fix this issue but apparently not. Truck ran terrible all day yesterday and this morning until I did this and I’ve now driven it hundreds of miles since then with zero issues and full power and no codes. Just a data point from a guy with a 2015 Ecoboost Expedition with 109,000 miles on her.
