steelnewfie
I was getting the same stutter around 1600RPM; it's not the TC. Like a rumble strip. Was lucky enough to throw a code and then cleaned the threads and reseated the plug on that misfiring cylinder. Now I have full power, steady at 1600 but I get a sharp, momentary drop around 3000 under medium-hard acceleration and the idle is still rough.
Previously I was able to get it to misfire almost every time by going on a slight uphill around 55mph; torque converter locked and lugging about as low as you can get it without shifting. This produces about the leanest burn these engines are capable of (from what I've read).
I've replaced five of the eight coils and all eight plugs. Other three coil packs arrive on Tuesday. Motorcraft plugs and coils; I would not bother with anything else due to these finicky 3v's. Warning they retail for a hundred bucks a coil.
Once I get the three last coils on, if it is still misfiriing I may drive it straight into Halifax Harbour. See how it does submerged.
Cancelled a 3000Km Xmas road trip because of my 'preventative' plug change...
Let you know how I make out.
