Five Star Tuned 2019 EcoBoost Expedition
FordExplosion
Ohio
Here's my 2019 Expedition with the Five Star Tuning 93 Performance tune. Very streetable tune. Gas mileage is about the same.
LokiWolf
Moderator
Richmond VA
The video is pointless without the time? What was the 0-60, and what was it measured by?
What Model Expedition? 4x4? Max? Limited? On 20's or 22's?
DWs-TTEB
Evans, GA
@LokiWolf do you know the difference between “write calibration” and “write entire” when using the RTD/HP-Tuner to flash a 5Star tune to the ECM (“write entire” is the only option for TCM)?
4thGen Expeditions
LokiWolf
Moderator
Richmond VA
4thGen Expeditions
Always write Entire...
joethefordguy
this is the kind of response I always find very frustrating. the question was not "which to choose". the question was "@LokiWolf do you know the difference between “write calibration” and “write entire” when using the RTD/HP-Tuner to flash a 5Star tune to the ECM (“write entire” is the only option for TCM)? 4thGen Expeditions
can you tell us the difference between the two?
thanks for your time.
jg
LokiWolf
Moderator
Richmond VA
jg
The person who asked the question was PERFECTLY fine with my answer. Sorry it wasn’t good enough for you....[emoji2957][emoji22]
One in theory writes just what changed and one writes the whole file.
I have used HPTuners software and hardware on 5 of my own vehicles and have helped probably 50+ use the software and hardware over the past few years. I have never had the “write calibration” work without error. Maybe it is the Ford Computers, maybe it is my luck. Write entire works everytime. It is also what ZFG(My Tuner of choice) recommends and he makes me look like a Rookie with as many people as he has helped and tuned.
Hope that is good enough...
5280tunage
colorado
I have a few questions for others regarding a 2019 tuned expy.
I have a 2019 Platinum, tuned, with quite a few aftermarket parts that I did discuss with 5Star ahead of time, so supposedly the tunes took that into account. I'm not new to tuning, I've tuned many other vehicles quite successfully.
I have both 87 and 91 octane performance and daily driver/tow tunes from 5Star. 93 isn't available in my area. And on the daily driver/tow tunes I did actually ask them to re-enable the auto stop/start as I don't mind that, and I spend too much time at stop lights.
In the past, tunes have always added performance, but depending upon driving style, I've never had a major difference in fuel economy. So far though, with the 87 daily driving/tow tune, i'm seeing roughly a 10% mpg difference in town, and a 15-20% decline in highway mileage. Anyone seeing similar differences? My entire hope here though, is to maybe even drop down to 85 since that's more common here, and given the fact that our gas here starts at around $3.70/gal (paid $4.59/gal this weekend in the mountains) for 87. But again, drop down to say 85 but get similar performance to when I was using 87 or 91.
How about the eco tunes from 5Star. Anyone have any experience with those and what was the outcome? I personally don't like the way the expy drives when I put it in Eco mode, so I'm curious how the experience is with the eco tunes?
Also, one more thing I noticed. Took it on a 3.5hour (each way) drive, up and down several passes this last weekend. One behavior I've never seen before so I suspect the tune (but can't say for sure), was a weird turbo pressure and blowoff valve issue. While under super light acceleration uphill, essentially to keep speed rather than to gain speed, the boost gauge would go nuts, showing pressure gain, then immediate drop and you can hear this whistle, essentially from the blow off valves, over and over until I take my foot of the gas completely. Once I did that it was fine. This didn't happen every time, probably 3 or 4 times total. And of course you could feel the lost of power, sort of a light lurching feeling. Any one see anything like this? It hasn't happened in the 20k miles I've had this car.
I will say, the rears break loose far too easy now :)
DWs-TTEB
Evans, GA
I have had 5Star tunes (93 perf, 93/89/87 daily/street/tow) flashed via HP-tuners/RTD on mine for over a year now. I 90% of the time run the 93 perf. MPG AVG dropped a lot. Went from 17-18 to 14.5-15.5 MPG. When I go on a trip of more then a 2 hour each way drive I throw on the 93 daily and the stock tires. HWY MPG AVG goes to 22 and around the house to 16-17 MPG. Eco mode on this same tune makes cruise control slow at adding speed & the same for normal acceleration. No MPG added at all for me. I have never had my turbo PSI gauge do what you mentioned. With your new turbos, 5Star needs to work this out for you.
LokiWolf
Moderator
Richmond VA
When you are cruising on the highway, with the Performance tune, is it staying in 10th? Is it locking the TC? Still thinking they are overfueling it at low RPM's to help it spool. Also, the SCT has less control over some of the tables than HPT. So the same company using SCT vs HPT could have differences in the tune. Explaining @DWs-TTEB different experience vs @5280tunage even though the company is the same.
Just throwing ideas...
DWs-TTEB
Evans, GA
Hey @LokiWolf long time no post! Glad to see you in here again! I know, bring Tapatalk BACK...
5280tunage
colorado
Got in touch with 5Star today. They are working on a solution for what they called "turbo surge". Look forward to getting that taken care of, I'll report back when I get it applied and try things out.
black_limited
VA
Yup that’s rather common actually.
FlyBry
Dallas, TX
Hello Gents
Re: How about the eco tunes from 5Star. Anyone have any experience with those and what was the outcome? I personally don't like the way the expy drives when I put it in Eco mode, so I'm curious how the experience is with the eco tunes?
I ran the 5 Star 93 Perf. Tune in Eco mode for 2503 miles, Dallas to St Louis to MN in July for the family vacay. I Noticed in Eco mode, it will downshift a gear or 3 depending on grade, to maintain speed, but always kept the boost at very low levels, or no boost at all. The SCT display usually showed a vacuum between 9 to 17 while cruising, depending on grade & speed.
Same Tune, In Std. mode, similar highways + 75 mph, it will hold the gear, or drop down to 9, and add boost to maintain speed.
Same Tune in Sport mode will downshift and add boost to very quickly maintain speed.
Over this vacation, averaged 20.6 mpg for the 2503 miles. I am happy with that, considering 2 adults + 2 teens + luggage for 9 days & the speeds involved + lots of stopping for pictures, etc.
apex96
PA
Hello Gents
The eco tunes will keep you in vacuum longer before you'll see any boost added. I have not seen any noticeable gains in MPG from them. Take this with a small grain of salt as this is my experience with a 2015+ F150 and their economy tunes. I ended up daily driving their adaptive octane tune as I frequently switched between 87, 88, and 91 octane fuels with the addition of an octane booster from time to time.
