crorad
Got a flat tire on my 2018 Expy. I didn't realize that on the OEM lug nuts there is a flimsy aluminum cap over the actual nut. When I tried to remove the nuts the caps were either swollen and I couldn't get the lug wrench on or if I did they would just spin over the actual nut. It was impossible to loosen the nut or remove the cap with the flat tire kit provided. Luckily I was in town and my wife drove me to an autoparts store to buy a stripped lug nut remover. With this I was able to get the caps off but removing each cap from the extractor was a real pain on the side of the road with limited tools. Now I needed another ride home to get more tools to get each cap out of the extractor. What should have been a straightforward tire change in less than 1/2 hour ended up being an over 4 hour ordeal. I immediately got all my other lug nuts replaced with better quality single piece nuts at a local tire shop. Buyer beware that this doesn't happen to you in the middle of nowhere! Did a web search and there actually has been a class action lawsuit regarding this but it was dismissed. http://www.fordproblems.com/swollen-lug-nuts/ Maybe if enough people complain they will be forced to do a recall.
