Fog lights
Shreveport
I’ve replaced the bulbs and checked the fuse yet they will not work. All wiring is in tact. And yes I looked up the proper way to turn them on. Is their something I’m missing?
Dustin Gebhardt
Tulsa, OK
I'm assuming that you've pulled the headlight knob out (toward the driver) to turn the lights on? I know that it took me a little bit of experimenting to figure this out. (Or I could have just read the manual). And the headlight switch it not in the "Auto" position, or if it is in the "Auto" position, then the ambient lighting is enough to turn on the headlights, right?
ssmock
Kansas City, KS
I had a broken wire at the fog light connection causing mine to flicker and finally fail. looked like a weak connection from the factory. Worth checking out anyway.
