For those adding an amp & sub to factory box
scoot0073
Georgia
Good work
Sent from my SM-G965U1 using Tapatalk
Hey brother I got this mess going on with to many battery terminals going to the Hot post on my battery. And every time I open my hood I keep saying Man I gotta do something with that mess..lol
Do u have any suggestions or a link to a battery post terminal junction block that would accommodate this many wire's.?
Auto Zone and other store only have a block that accepts like 2 wires with set screw's.
I couldn't find nothing on Crutchfield Audio website.
Sent from my Nexus 6P using Tapatalk
Go to Crutchfield.com. They have all the connectors you'll need to run multiple hot leads. They also give great free advice.
scoot0073
Georgia
I did and didn't see anything that would accept 4 to 5 , 8 gauge wires.
When I used to run multiple amps, I'd run a 0-2 gauge wire to the battery, then a plastic battery divider that took up to o gauge coming in and 4- 6 gauge Allen screws on other side. If your running monster current amps that need bigger than 6 gauge, you'll need something bigger, they make them. Check with a car stereo install/sales shop in your town. How big is the wire coming off your biggest amps?
scoot0073
Georgia
Thanks for your time.
Currently I only got 1 Amp Rockford 1200.1
Pushing a single Skar VXF-12-D2 sub.
I'm using the recommended hot n ground wire for the Amp 4 gauge .
I guess the easiest thing to do is make a buss bar with 4 or 5 posts .
I'm not sure how many amp it's pulling but Rockford recommend using a 100amp fuse off the battery post for this amp so that's what I got.
johnboneske
Ohio
why do you need it to except 4 to 5 8 gauge wires? I use a "stock" terminal with each other the copper screw down terminals on each side, along with the starter wire and my 6 gauge under the main spot to "crimp" the wire, works perfect.
johnboneske
Ohio
Don't forget 6 gauge is good for 60 amps, 4 for 100, and 2 for 150 amps, and 0/1 for 200. I have an old school Orion HCCA 225 bridged on a pair of newer Kicker 12's, I have never had a fuse fail. And, those who know, will know how powerful my amp is(was laying around so why buy something else, when it doesn't get any better than an Orion?
I used to compete when I was young and single. Went to finals 3 years in a row in IASCA, once with RF, then with PPI and finally with Orion. Yes I had alot of money to waste then, and did so every year with new systems.
gnorman
