My 2007 ford expedition is not starting.
Replaced the battery.. the starter .. spark plugs and coil packs.
Clicks over as if battery was dead.
What are the main relay fuse part numbers by the way?
I would appreciate some help please from any one at this point..
Welcome to the forum!
VOLTAGE DROP TEST (digital voltage meter required) will test all your battery cables and connections to make sure the voltage is getting to where it needs to go. This is always a good place to start so you are not running in circles trying to diagnose something that just needed power.
Voltage Drop Test: is testing the connections without having to take them apart and you can work your way right to the problem.
So you have a digital volt meter($15@walmart) and you put the red on the positive battery post and the black on the negative post you will get how many volts your battery is putting out. (12.v)
now that you know your digital volt meter is on and working,
The goal is to read 0 volts.(means all good connections) the more volts you read the worse the connection. (Ex 1.5v it's a little dirty all the way to 11.3v means almost no connection.)
(notice i dont say black and red colors here, that is because it doesnt matter what colors where)
Put one wire on negative post then put the other wire on the clamp that is on the negative post. If you read any volts at all those volts are being lost in the connection from the post to the clamp. (Ex if you read 1.5v you need to clean the battery terminal). put back together and move on to the next connection on the wire and one still on the battery post.
This can be done on both positive and negative sides the exact same way.
Look up (Voltage Drop Test) You tube vids get a little techy but my explanation should help a little.
