ive had a clunking noise in the fron of my 98 4.6 expy with limited slip axles for about a year now, more of a clanking bull dozer sound. its most noticeable going slow in a parking lot, it isnt nearly as loud when i put it in 4wd, but it is still there. i jacked up the truck and in 2wd the front wheels spin freely from each other and do not turn the front drive shaft, but when i drive down the road the drive shaft still spins. i did a burnout and had a friend look under the truck to watch the front drive shaft and the front drive shaft spins in 2wd doing a brake stand, so the transfer case IS turning the ds, but what is my clanking?ive noticed it "clanks' about 5 times to one rotation of the wheel. the noise is NOT coming from the wheels, but rather somewhere behind them., ive noticed the front u joit on the front ds is bad, since my tranfer case is turning the drive shaft, could i be hearing this bad u-joint? also why is my ds still turning in 2wd? i just put a new transfer case motor on it, and a4wd, 4x4hi, and 4lo shift fime, although sometimes it siound like it has to try and shift to 4 lo twice, like it makes 2 or 3 clunks going to 4lo instead of just one. is my transfer case bad? i always thought till recently that the sound was whatever disengages the front axles not fully disengaging.
