Front end noise
Supercompdad
Cheyenne Wyoming
I have a 2017 Platinum with 35K miles. So I have the buzzing or whirring sound that appears to be coming from the left front wheel. I’ve done all the suggested checks that I’ve found online. Put on a new set of tires. IWE appears to be functioning properly. Can’t believe it’s a wheel bearing as it’s done this for a couple thousand miles with no change in noise. Does it in 2 an 4 wheel drive. Does anyone have a definitive way to troubleshoot this? Thanks.
AWAR
oregon
Does the noise change as you steer slightly left and right on smooth asphalt? If so I would have your wheel bearings inspected. I worked in a fleet shop and we had LF wheel bearings fail on several 2005 F-150 4x4 trucks when new. So mileage may not be an issue. We never had a passenger side fail over the 200k mile life of these pickups, only the left and it was early on.
S
Supercompdad
Cheyenne Wyoming
Actually it does change a little when steering to the left. Don’t notice it as much when turning to right. Thanks for the info. Guess I’ll look harder at wheel bearing.
AWAR
oregon
Nice and quite again like when it was new! Happy for you.
