Front Hub Solenoid Location?
tomeads
I have a 2016 Expedition and have a vibration when turning at low speeds. Where is the Front Hub solenoid located? I know where the rear axle is as the oil will be changed and the Friction Modifier added.
Jamo
Lee Center, NY
That's a great video...Thank you for posting. I was having a problem the other day with my '14 EL LTD making that light grinding noise and not locking in. I have an extended warranty so it will get fixed (dealer wanted me to drop it off for who knows how long and it's my only work vehicle these days), but on my time now that I know what's going on. It was 15 below zero when it froze up on me, now it seems to be OK, (but mostly in 2wd)?? Still going in when my schedule allows. I really like knowing what's happening before handing it over. I'd do it myself if off warranty.
Thanks again...
T
tomeads
Maybe I did not describe the part correctly. Is there not a vacuum solenoid (IWE) on the firewall as on older models?
The location is dependent on model year. I believe yours is indeed on the firewall. Models with the big fan shroud with the e-clutch fan it’s in the shroud up front.
