I have an 04 XLT with manual climate control. Adjusting the temp control has no effect on the air temp out of the vents with or without the a/c engaged. Using the Max a/c setting does put out cold air. I don't hear any noises under the dash when adjusting the temp control.
Based on what I've read, I'm thinking it's time for a new actuator. Based on the symptoms, could somebody verify that it's the actuator, or if I should be looking at something else?
Thank you
Thank you
