Fuel filter, are you in there??
Adieu
SoCal
...if so, how do I get you out?
And if not, where the hell are you????
ExpeditionAndy
Fort Wayne, Indiana
I thought it was above the tank where the fuel line exits the tank. I think there is one of those Ford Quick connections on it.
A
Adieu
SoCal
Not here either
....but wait up, isnt this it????? However, why the hell is it UNDER THE ENGINE, by the front right coilover????
Muddy Bean
Quoted from another site:
Tylus's AvatarTylus , 07-10-2009 02:34 PM
under the body on the left frame-rail. about the size of a 20 ounce water bottle.
fairly easy if you have the tools...and a few warnings.
You need to buy A/C Line disconnect tools. If you ask a parts store, they'll know I'm talking about. It's a chunk of plastic that has a slot so you can fit it over the fuel line. Then you run it under a compression fitting to loosen a lock.
Also, Ford has started using these damn blue clips. You unlock them, partiall relock, then unlock...it's a major PITA and alot of people have broken their blue clips.
The front of the filter uses the A/C fitting, the rear of the filter is the blue clippy thing.
here is a great description of the blue clip.
http://www.f150online.com/forums/200...lue-clips.html
btw, let the Expy sit for a few hours before you do this. Hopefully some of th pressure will bleed off...also, have a rag handly to keep the spray off your face
A
Adieu
SoCal
Yeah reading is grrrrreat, I know it **says** it would be there
....but in the SSV, it just ***ISN'T***.
Now there IS a fuel filtery looking thing underneath(ish) the engine block by the passenger side front wheel well.... but no fuel filters on any frame rails
AllBoostNoEco
GA
I looked at a couple of videos, and they all correlate with this one:
Top-front of the gas tank. Does your replacement filter have the two lines in, one line out like a normal 2009 Expedition filter?
lbv150
Northeast
What model year did they start with the in-tank lifetime fuel filter?
Muddy Bean
Sorry. Completely forgot yours is an SSV. Sorry [emoji52]
A
Adieu
SoCal
But, of course, there doesnt seem to be any info on it....cant even see if it's the same one
I'll probably give up and leave it to the dealership, dont wanna inadvertently screw something up
Muddy Bean
So from reading your various posts recently, it seems like you’re doing a full mechanical baseline. Something I should do soon.
A
Adieu
SoCal
...uh, maybe?
What's a full mechanical baseline? Redoing everything that usually needs redoing?
1997SCEBFEX
Northwest Panhandle
if you do take this on yourself, either now, or after Blue Oval, the procedure I've used to relieve fuel pressure is to start it, disconnect the fuel pump reset (passenger side behind the kick panel on my old '97) and let it stall. I also pull the fuse to my aux fuel pump that feeds the fmu for the supercharger.
my experience with the clips is to just go slow, steady pressure and the a/c line tool works just fine and sometimes it's the one that's just a bit smaller than what you'd think to get the clips to release.
I also put the dust caps from the new filter on both ends of the old filter prior to removal to keep the residual gas inside; a bunch of paper towels or shop towels are a must as there will be spillage. dry everything off real good in addition to evaporation.
good luck.
deweysmith
Montreal, QC
fordparts.com has this exploded fuel system view on the fuel filter part listing.
RenderIllustration.ashx
It should definitely be in the back by the tank and EVAP canister from the looks of the diagram…
Searching for the same part for a 2010 yields 0 results, so it looks like 2009 was the last year for a non-integrated fuel filter, as the service manual for my 2012 says "part of fuel pump" in the fuel filter part listing. It's possible that since yours is an SSV that it was built later and doesn't have one either, I would punch your VIN into fordparts.com and search "fuel filter" and see if anything comes up.
A
Adieu
SoCal
Well that box by the tank seems to be the EVAP shit....
What's the filter canister near the front passenger wheel under the engine, then? If not a fuel filter... Auxilliary tranny fluid filter, is that a thing??
lbv150
Northeast
Found this online...." it depends on the trucks build date, up to 9/15/08 the fuel filter is located on the side of the fuel tank and it is serviceable, after 9/15/08 the filter is part of the fuel pump and is not serviceable"
A
Adieu
SoCal
Huh
Does it last a lot longer, then? Or is it high time to change the entire fuel pump (I'm @ 175k mi)?
