Greetings......
I need to change the fuel filter on my 07 Expy EL......Several questions.
1. Where is the fuel filter located?
2. What is the tool I've read about that makes it so easy to remove the filter and where can I buy one??
3. How do I relieve the fuel pressure? If on the fuel rail, where is it located? or do you remove the fuel pump fuse/relay and start the truck and let it run till it dies? If by the fuse/relay method, where is the fuse/relay located?
Thanks in advance..........
Swmpbgy1
Swmpbgy1
