Fuel Filter
Finishblade10
Arizona
Good Morning
I have a 2012 EL Limited 4X4 with 142,000 on it. I stepped on the gas pedal harder than usual to merge onto the freeway. almost immediately, the truck shuttered and the check engine light came on. I got off the gas instantly and the light went off and the truck ran fine the rest of the trip. Although single occurrence happened a week ago, the light has stayed off and it has run fine every since. (Have not aggressively accelerated since)
I'm the second owner if this Expedition so I don't know the service record. I have a Motorcraft Fuel Pump on the way next week. Before I drop the tank, I want to look into changing the fuel filter first. I'm told that the filter is located on the inside of the frame directly below the center of the drivers side passenger door. I've looked all along the frame from front to back and see nothing. Its so tight between the tank and the frame below the door that there's no room for a filter anyway. Is there a possibility that this filter is located on top of the tank or worse yet, inside the tank? Thank you in advance for taking the time to help with this.
99WhiteC5Coupe
Good Morning
There is no separate, external fuel filter on the 2012 models. The fuel filter is part of the fuel pump module.
Why are you replacing the fuel pump?
Did you have the vehicle scanned for any trouble codes?
F
Finishblade10
Arizona
I’m replacing it because we’ve got a 1000 mile road trip coming up next month that will have several uphill grades and I fear being broke down in the middle of nowhere. There are no codes. The check engine light has not returned.
My neighbor has the identical vehicle and his pump went out at 120,000 miles. I’d rather be proactive about this instead of saying “If only I would’ve….”.
apex96
PA
Doubt it’s the fuel pump/filter assembly. You’re way overdue for new spark plugs, coil boots and coils, if you haven’t changed them already. I’ve got a hunch that your misfire under acceleration was due to bad plugs not poor fuel pressure/supply.
The Chairman
TX
I agree. Classic spark plug misfire.
apex96
PA
Wouldn't misfires show up in the scan?
Yes there should be stored codes but the OP never mentioned that they pulled any codes. I don’t believe they tried to pull codes, they simply assumed it must be fuel starvation issue.
othermrsikes
