Fuel nozzle shuts off when filling
Bailey
Milwaukee
Hi gang,
When I go to fill up, IF I'm 1/4 tank or below, the auto shut off will keep shutting off. Once I get around the half tank mark it is ok and I can hold it wide open. 2020 King Ranch. This did not happen with my 2016.
I have tried different stations, putting the nozzle in differently, nothing seems to work.
You can actually hear it filling up the neck. Maybe a vent issue.
Mlarv
Eastern TN
Sounds like a vent tube problem, why not bring it to the dealer when low and have a Tech come with you so thy can see it happen.
joethefordguy
my wife's 07 mustang occasionally does this. because it tends to improve when i bounce it on the suspension, i agree it has something to do with the vent, but I've never been able to fix it.
Highlightreel
MN
09 Suburban did this to me all the time in the winter months. I even bought an entire new gas tank assembly and it still did it. VERY frustrating when it's cold outside and you can only get about a half gallon before it shuts off. Took forever and was a miserable time, especially when I was low.
1970Maverick
orlando, fl
Does it happen at different gas stations?
I get gas for my Expy at Costco and never had the problem you describe but, recently they changed the nozzles so that you have to purposely push it in to start the flow and keep a little pressure on it even with the squeeze handle locked on. Normally I don't have any problems at other stations.
My wife drives a 350Z and she has random occasions of the pump stopping when the tank is 1/2 full, it happens at different stations. Sometime bouncing the car lets her finish filling it and other times she gives up and leaves with the tank 1/2 full. It's a vent problem and Nissan has a service bulletin but the car is long out of warranty so the dealer wants $250 or so to fix it.
sixstring
Florida
I have a 2020 platinum and occasionally have this fuel fill problem.
It does not matter what gas station I am at.
I've had it happen and then drive straight to a different station (different brand) and it still stops constantly.
It does this about 10-20% of the time.
Zig10
Mid Atlantic
Had that problem in my 2020 Ram. Turned out to be the in-line check valve that went bad. Dealer replaced it under warranty (it's in the tank assembly on that vehicle) and the problem went away.
spiderman865
Chicago Area
Hi gang,
Was this issue resolved?
gledhill
canada
I constantly have this issue and have taken to the dealership and they have ordered a new filler neck to try and solve issue. Been 3 weeks and still waiting supply issues.
aistbird
PNW
It happens to me (2020 XLT) when the tank is 5-15% full, shuts off 5-8 times during filling, mainly while below 50%. Being to dealer 2 times already with this, apparently they didn't fix it, going to #3 in a month or so
duneslider
Utah
My jeep has this problem and the fix is a new fill tube. There is a one way check valve or flap in the fill tube and on the jeeps this degrades over time and doesn't open very well to a fast flow. If I set the pump at the first notch and not the second it will fill no problem but if I try to do it at the second notch for a faster fill it clicks off every two seconds.
So, I would not be surprised if there is some sort of check valve on the expy too and I wonder if you try filling it slower if it won't click off. It could be a vent problem also.
