Got my box today
LastExpo2000
Corpus Christi, TX
Box of rear coil spacers that is! Now I've asked this several times but which is the best way to install 1" rear coil spacers? Do I need an alignment after install?
JDMitchell
Fort Leonard Wood
I have a better feeling about my coil spacers being on the top. Not sure why, maybe I read it somewhere a while back when I was doing my research. Also, there is no way to align the rear end of a 1st gen Expy since they have a solid rear axle. If you do a torsion twist in the front you might have a slight change in camber/caster.
panda24619
San Diego
i went to go get an alignment and i said screw it and did the TT right before. now that i need new tires, slicks are for drag racing not street, im going to lower the pass side a bit, its a little higher i think by 1/4 inch and then get it done. hopefully i get the spacers soon. but need a yob first.
