Granetelli coils
Erich Zeppelin
Destruction Bay, Yukon Territory
Bought a full set of Granetelli Steet Fighter coils 21-2001-SF for my 1999 5.4L. Worst mistake I have ever made regarding the Expedition. Constant misfires on multiple cylinders, terrible customer service, and over $900 in diagnostics. Avoid Granetelli.
FordandPolaris
Saint Cloud, MN
Thats too bad... I don't know what the parts-houses are like in Alaska but if you by chance have an O'Reilly somewhere nearby, I use their premium coils. The ones I have put in have run flawlessly so far. Probably the last thing you want to hear considering the money you have already spent is having to purchase other ones though... Now what type of plug are you using?
1koerner
mesquite tx
davis united ignition has great coils im running their SOS (sultan of spark) ign coils and they work great before these i had the msd blaster ign coils and the sos coils seem to give me a lil better off the line accel
whowey
Illinois
Accel has a really bad reputation in the off-road community. They fail due to vibration and heat. Are the Accel COPs better???
copper08
N.Texas
For sure no granettelli I had bad experiance with qoute H.P Throttle body very very bad customer service
svfetter
Louisville, KY
If you have aftermarket coils and have had no problems, consider yourself lucky. Coming from the High performance Mustang crowd, the finding over the last few years has been that none of the aftermarket coils are as reliable as OEM.
In addition, you must be in a very high horsepower application to even think of needing anything other than stock. Better places to spend your money
Expyguru
fultondale alabama
I run the granetelli coils on my 9.5 compression with 12lbs of boost and have not had a single missfire. I have the 60,000 volt. Plus only paid 300 off ebay brand new.
alaskanexpy
anchorage alaska
i had some cheap aftermarkets on my excursion. kept having missing issues. ended up putting 10 new motorcraft units in almost 2 years ago. been great ever since!
toms89
technical advisor
MD
I agree except that many have run aftermarket coils with no issues. But OEM has been shown to have higher reliability on performance oriented forums.
After market coils advertise higher voltages but the truth is the voltage only goes high enough necessary to jump the plug gap. It will not go any higher. Voltage is dictated by the resistance to jump the spark plug gap. Higher voltage (capacity) coil does indicate it has more windings which naturally have to be smaller. This can effectively lowers its current capacity. So if the voltage (stock) is enough to jump the gap what is the benefit of a higher voltage coil ?!
Theoritically you can increase your spark plug gap to take advantage of it but this creates other issues... such as increasing the likely hood that the spark will find alternative sources to ground other than the plug gap. (effectively misfire)
More important is a well encapsulated coil that will hold up under the conditions and spark plugs properly gapped. I would say aim for the smaller size recommended so the plugs have room to open up. This also decreases the likely hood the coil can misfire to ground elsewhere.
Maintaining a good seal between the upper portion of the boot and the plug well go a long way towards eliminating misfires as well. That's a known issue with the cops on these mod motors. Moisture in the plug well is just asking for trouble. Not the coils fault.... it will always fire to the point of least resistance.
Just my thoughts..
Stock coils here.. 14psi boost
