hooraah
Hey all,
Picked up (or agreed to pick up) a 98 Exp XLT with a 5.4L, 2wd, 197k miles from a family member for next to nothing. Its a bit rough (by a bit, I mean a lot) but this is going to be used for towing our racecar (Chumpcar Porsche 944 if you're interested) and more or less camping out of the back of in the pits.
I read through the sticky on 'what to look for' and I have a pretty good handle on most things. The Exp doesn't have much in the way of maintenance history. The PO had issues fixed when they came up but didn't keep good records and wasn't great on maintenance.
It runs decent, but will need a new battery off the bat. Its been sitting for around 6 months, but was daily driven before that. No misfires that I can tell. CEL is on with codes P0135 and P0155 for the O2 sensors, but no misfire codes. PO changed coils/plugs on a here and there basis as they became issues with little papertrail to follow. The 90 deg vac elbow was replaced by me a few years ago when I was helping the owner out with a stalling issue (which cured it). I also know that most of the coolant was replaced about 2 years ago when the heater core leaked it out all over the place. The heater core has been bypassed and wasn't fixed. We're in FL, I'm not worried about it.
The downshifts are a bit rough, as in it seems to slam into gear, but it still shifts at the appropriate points and doesn't slip. Not sure if this is a real issue, as I'm used to driving a 3000lb car with a 2.5L engine and a manual gearbox, so totally different size engine and transmission.
I plan on hitting all of the basics first - trans fluid, diff fluid, coolant, oil, and brake fluid, and will inspect the balljoints and brakes ASAP.
Now, questions -
I hear much about coolant leaking on coil #4. Where does this coolant leak from? Is the 5.4 one of the engines that needs a manifold gasket change when the coolant leaks, like on my friends 4.6 F150?
Are the intake manifolds Al or plastic on the 5.4? If plastic, are they the ones notorious for cracking on the crossover coolant pipe?
Anything else you'd recommend (besides the usual stuff) I check or replace off the bat just based on age?
I imagine that at 197k the shocks are probably not great. Considering thowing a cheapo set of Monroes on from AAP. Some people say they're a bit rough for driving around town but that should be fine as, like I said, the truck is only going to be used to tow on race day. They've probably better than whats on there now.
Now, questions -
