Do not force the knob for the light switch
Lamp Switch —Headlamp
Removal
Disconnect the battery ground cable (14301).
Turn the headlamp switch knob to the headlamp position and pull the knob.
Insert a thin tool to release the headlamp switch knob and remove.
Turn the headlamp switch knob 180 degrees and install.
Turn counterclockwise until the back of the headlamp switch knob is in the OFF position.
Turn the headlamp switch knob fully clockwise.
Remove the headlamp switch.
Pull the headlamp switch from the instrument panel.
Disconnect the electrical connectors.
Installation
NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
To install, reverse the removal procedure.
