Hardwiring radar detector
eatonmom
Ohio
Any tips on doing this? I have an escort with the smart cord for hardwiring (I have a 2016 Exp if that helps). Anyone know which fuse to pull for using the add-a-circuit without me having to find a meter?
bloodhound
Merica
Check your manual, it tells you which circuits are unused.
Habbibie
Is it Christmas yet?
Chicago
Well I was going to say what's the point in that but I remembered the EcoBoost is in the 2016's not the good old grumpy triton, that old grumps takes a week to get fast enough to attract any attention.
FisherPete
Portland, Oregon
You didn't indicate what type of detector, but if you have a "SmartCord", I suspect you're talking about an Escort. Escort has a great forum where this topic is extensively discussed. LINK HERE
The SmartCord is normally used for windshield mounts. The "CI" models of detector are designed for covert installation, with both the detector and the display mounted in hidden locations, but without the SmartCord option.
montecarlo31
Just a heads up you may want to make sure you do not have the soundscreen glass, I noticed a sizable drop in detection distance with the glass on my '13 and another brand detector. I believe the lamination impacts the pass thru ability.
jeff kushner
North of Annapolis
You will lose the smart-cord capability if you hard wire it leaving you to have to reach up to press off the sound each time you get a hit. I mounted my 8500X very low on the windshield(between the windshield wipers) using this:
http://www.ebay.com/itm/171967997517?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
and just tuck my smartcord into the little storage box on the dash right above the covered power outlet. It's very convenient there and allows me to remove to move it over to the bike when I ride.
You should do what you want of course, just letting you know that the smartcord is a nice feature to have.
jeff
Flexpedition
midwest
FYI, a few years ago Escort & Beltronics introduced hard wired smart cords that were not the typical coiled ones that plug into cigarette lighters. Here is my Smart Cord I installed in my Nissan truck, sometime around 2008/2009:
Not mine, but here is the latest model from Escort, Smart Cord Live, installed in a BMW from another forum I follow:
To answer OP's question, if you want to tap a fuse, try #31 in the front passenger kick panel is 10 amp, which is more than adequate for the self dimming mirror and compass module it protects. You can tap a fuse there, but I'd strongly recommend just tapping the (ignition on switched) moonroof switch (if you have one) or even the manual map read light circuit. Connect your power and ground up there, and then run your control wire to the unit down the a-pillar to wherever you want to mount it. Short pigtail from that overhead console to below the rearview mirror where I'd assume you'd want to mount your detector. In other words, I see no reason to run new power and ground wires from the fuse box.
I have the Soundscreen glass and all my glass is tinted on the Expedition. In the few instances I've used my detector I've noticed no performance issues with it.
FisherPete
Portland, Oregon
My 2012 Expedition has SoundScreen glass. I haven't noticed any problems with detection through the windshield. I use my Escort 9500ix continuously and have a 50 mile daily commute. The biggest problem is alerts from other vehicles with lane control technology.
jeff kushner
North of Annapolis
Gee, I learn something every day! I never saw those new remote adapters before.
I HAVE noticed that my detector doesn't seem to work nearly as well as it does in my car but thought that it was just my imagination. A couple year ago when I bought it, I disassembled it so I could seal all the openings for use behind the windscreen on my vstrom1000. Its always worked like a charm on the bike and has definitely saved me from more than one ticket had the officer chosen to pursue. I only say that because quite often, the police will use discretion if you are running a bike at 90mph on the superslabs but are riding like you own a brain.
When I installed it into my new truck, I did notice a drop in "perceived performance"(b/c I have no way to measure it). I'm now thinking of a new unit mounted in the grill.
Let us know where you ended up wiring it, I may want to follow your lead!
jeff
ElliottM
East Wenatchee, WA
Hi, I am jumping on an old thread, I know. I have owned my 2016 Expy for all of two days now, and I'm looking to bring it up to ***** with the gadgets I had in its predecessor. Specifically, I am looking to wire a radar detector and a dashcam, and I am hoping to tap into wires in the overhead console. I have searched the threads here on this site and across the web with no luck finding a wiring diagram for the console. Any suggestions?
jeff kushner
North of Annapolis
I bought a hard back version...damn book is 1-1/2" thick of nothing but wiring diagrams for the 2016 Expy! There are one hell of a lot of diagrams in it! I figured that it was VERY close to the 17's so I bought it.
jeff
Newport News, VA
I need to hard wire mine just need to get to it...
Sent from my SAMSUNG-SM-G935A using Tapatalk
