LCField
Has anyone had any luck finding the INTERIOR FUSE PANEL? The Ford Video shows and also states that "The fuse box is located behind the passenger side cowl side trim panel", but obviously, I'm not smart enough to find it....
You are correct! But folks get real frustrated and lash out. You handled it well.Glad you got it worked out....
Next time someone tries to help you, you might want to give them a thanks instead of telling them to stop responding when they're trying to help.
I can see Ford putting it there. They are probably concerned about folks who haven't a clue messing around. Or, they don't care how difficult the end product is to service.Will do! My apologies, I didn't handle that correctly. I got a little frustrated and I should have looked in the manual before I went to the forum. I do appreciate your help and I stand corrected. I still can't see Ford placing the fuse panel without an access door.
Hey Grrumpy, I'm sorry again that we got off to a bad start, and again I apologize for that! I went out of town this weekend and returned this morning. I started installing my Dash Cam, and Radar Detector VIA Hard Wired that I removed from my 2021 before I traded it for this 2025. The Dash Cam has a wiring harness Adapter to connect into the Rain Fall Sensor, but the Cobra Radar Hard Wires into the Fuse Box Panel just like the 2021 model did. Having to remove the whole kick panel is a pain in the a$$ instead of simply opening an access door, but I got it done. Another Clean install job. Thanks again my friend, and again, sorry about the rough start!Glad you got it worked out....
