Having an issue with overheating while running the AC
Strawberry
Porter, Oklahoma
AC was not blowing cold air so my husband added refrigerant it seemed to be doing just fine for a couple weeks then I noticed when I was driving it that it wouldn't blow as cold of air then I started noticing that it was getting hot in my truck was getting hot I'm sorry we get out and I would check you know to see if it lost any water and just a small amount would need would need to be added every time but it's just slowly gotten to where it gets hotter and hotter I already needed to do a radiator flush or cooling system flush but I figured I would start with that to see if that's the problem before I did anything else I'm not totally sure do I need one bottle or two bottles of the coolant system cleaner I have a 5.4 Triton motor in my 2001 Ford expedition four-wheel drive and would it be better if I drained the block when I drain the radiator if so how do I do that I don't know how to drain the block I've drained the radiator before in the last radiator I had in it
Mr Big
Tampa Bay, Florida USA
Your post is a bit confusing:
Are you referring to the A/C not blowing cold or the engine overheating or both?
If your husband added freon to your A/C system that's a good indication you have a refrigerant leak. If your vehicle is getting hotter engine wise, then you could have a bad thermostat, clogged radiator, low or no antifreeze, etc. If your coolant level is lowering consistently, there is a chance you have a leak. Also depending on the mileage, check to see if you have bubbles in the reservoir when the engine is running. That could indicate a bad head gasket.
