mtrosclair
2022 Timberline, I'm having an issue with getting the new tire size to work and I am looking for advice or guidance.
I posted it in the gen 4 forum when I understood even less but with no replies.
www.expeditionforum.com
Stock is 265/70 r18, new tires are LT275/70r18, I initially just tried changing the circumference in the plain english part of FORscan but the speedo was 3.5 mph over actual. After learning that a PCM relearn was needed I also learned that the maximum diameter value it will accept is 2610mm, which still gives a 2 mph discrepancy. The value would need to be 2649mm from what I can find to produce an accurate result. Looking at some F-150 forums there do appear to be ways around this but I realize there may be differences with the Expedition.
2022 Timberline Tire size adjustment with forscan
So, I finally got new tires and I need some help because for some reason I am not understanding how to figure out getting the tire size in forscan correct. Long story short I decided on the Firestone Destination XT and they were not available in the stock size of 265 70 r18 with the white...
