Hazard Lights
Mark2018
Massachusetts
the hazard light on my 07 expedition have started to randomly turn on. This usually happens when I first go to start the vehicle. Other times the vehicle will be parked for hours and they just turn on. I’ve seen other posts regarding this but haven’t seen where a solution was posted. Appreciate any suggestions.
99WhiteC5Coupe
Speculation - but I’d suspect a bad switch.
M
Mark2018
Massachusetts
I replaced the switch in the dash and the turn signal in the column. Still randomly turning on. They will flash for 30 seconds then stop and nothing for awhile.
Plati
Does that year have a problem with water intrusion into interior fuse panel?
Gary Waugh
Princeton, TX
also the Ford remote start will flash the indicators, so if you have that feature fitted it could be dying (or water has got inside and messing it up) and causing the issue!!
Gary
