strokin393
Will a headlight switch from a 98 or 99 work in a 97 Eddie bauer?
The dimmer works for the climate control and I know dash is or should be hooked up, the warning lights come on when I turn key. All works but dash lights to see at night.I would grab a volt meter, get a schematic and see if power is going to the wire that feeds the dash lights, doesn't the actual dimmer switch control the dash lights after the headlight switch is turned on? Check and see if there is power to the dimmer switch after the headlight switch is turned on.
They all work.Check all your taillights and headlights.
I'm not sure if they light up, the truck won't start now after changing plugs. I think fuel pump or something went out as well. Truck has few problems.It kinnda sucks you have a 97 since I don't have a wiring schematic of the dash illumination, only for 99-03. The 97-98 Expys have different wiring in some places.
See if you can find a wiring schematic for your year (alldata?).
Do your cruise control buttons light up? For the 99-02s, the light blue/red wire seems to be used for illumination of everything that lights up.
