andrew_s
...but ac does. Anyone else have this issue?
Hi andrew_s,
I recommend having this issue looked at by your Ford Dealer. You may locate one here.
Always here if you have questions.
Todd
The newer expeditions and the nicer models have two heater cores. There is one behind the fire wall (front heat) and one in the back for the reaar. The rear heater core is located usually on the driver side rear panel in the inside of the vehicle usually in and around the wheel well. Its probably clogged if your getting no heat at all. There also is a blender flap in the back that can fail thus resulting in no heat getting mixed in with the incoming outisde air so all u get is fricken cold.
...when heat is commanded the system move the air to the lower vents.
Hi andrew_s,
Todd
Lots of help.
All HVAC components are mounted on the RHS rear wheel well in the "3rd" gens. I realize he gave the worst description of the problem possible but I know on our '13 king ranch when heat is commanded the system move the air to the lower vents. I'm not sure why anyone would want heat coming from the top since hot air rises however I guess he may want it for defogging windows?.
Yes, I believe your system is working as designed. If you select rear heat from the main a/c controls in the front of the vehicle it will blow from the floor vents. I believe there is an option on the rear controls (back of the center console) to select floor or ceiling vents. Try that.
