Dr.Spank
I am hoping someone on here can verify what a mechanic has told me.
2002 4WD Exp.
Finally needed to start using the heat this year and there is none.
well, the heat works for about 30 seconds and then gets cold. Every once in a while, while driving longer distances 30+ miles, it will actually get hot for a while and then stop.
Mechanic told me it's the heater core. He said also that while replacing the heater core, I should replace the "door/valve" (opens and closes for the heat?) Not really sure what that is, but he said Ford has a crappy design on it.
I'm ok with replacing whats needed if I'm paying the labor to remove the dash anyway. i might as well replace what could go wrong under there.
My question though, is....can it be anything other than the heater core??
Is there anything else that "I" can check or change before I dump a gob of money down for the heater core.
Thermostat was changed and the mechanic apparently did some sort of "flush" .
If theres anything else it could be I'm hoping you guys in here can help. I really don't have the $500+ to slap down right now.
Pete
2002 4WD Exp.
Pete
