Heater Vacuum hose
stamp11127
Temple, Georgia
Vacuum is only used to control the air intake and panel or floor settings. Doesn't have control over the heater core temp. per your other thread. Sorry...
But for a test, there is a large difference in vacuum between idle and WOT. Idle is higher vac than WOT. See what happens between idle and 1/2 throttle.
stamp11127
Temple, Georgia
Does the panel selector work as designed?
Still sounds like low coolant flow or blend door. Low flow can be caused by low coolant or blocked restrictor.
