Ok so a couple nights ago my battery died. I was able to jump the battery but when I took the jumper cables off the truck would die again. I bought a new alternator and battery but the battery indicator light keeps flickering. If I hit the gas it shuts off until I get to cruising speed, then it comes on again. If I go over bumps it flickers on and off. I checked the starter and noticed the starter selonoid is loose. Could this be causing the battery light to flicker? Need help before I spend more money on a new starter.
