help identifying a part
11b4v
Alabama
Anybody know what this part is? Sits on top of the motor, behind the air intake. Part number is too tiny to readE6A6588B-F65C-45D0-96F2-D8239592A23A.jpeg005D0F59-D96C-4BB8-8342-612B37826581.jpeg
11b4v
Alabama
Much Thanks!!!
Since I have you on line, any clue as to what problems it causes when failing?
Allen Miller
Indiana
if you can't read that part number, you need to have an eye exam.
As for what the purge valve does, it's part of the evaporative emissions system. Failure of this could cause rough idle, low gas mileage, and your Service Engine light would come on.
Adieu
SoCal
Much Thanks!!!
Sorry, Im not even sure WTH it does lol
....I just zoomed in and checked if the alphanumeric code I inferred existed and matched the part w/ google
rjdelp7
2000 XLT
NY
Much Thanks!!!
Why did you remove it? A good rule of thumb, if you are not familiar with a repair, don't mess with it. Do you have CEL?
11b4v
Alabama
Pulled it and re installed for experimentation. Have had a long time vacuum issue where I lose vacuum boost to the brake booster when braking at speed or acceleration. I’ve replaced the booster and master cylinder and did a full bleed
It appeared to tie into the vacuum/ brake system from behind the block, but now I/we know otherwise
