Help identifying noise (on 2013) - possibly under the hood
ManUpOrShutUp
PA
So, here's a twist. It was 59 degrees today. I drove my Expedition for a while to run errands in the bigger town, 25 miles away. When I got there and stopped at the first traffic light the sound started up. I turned off the radio to hear it better & sound kept going until I took my foot off brake. It happened a couple other times during idle. I parked in my brother's driveway, took key out of ignition & got out... we sat outside and visited for 30 minutes when suddenly the vehicle made the noise on its own. I opened the door to pop hood & sound stopped. He said it was the radiator fans. So I started the vehicle & let it run. The fans never came on and there was no noise. So, is it normal for the fans to kick on 30 minutes after the motor is turned off in what is now 52 degree weather? If so, fine... if not then I need to use my warranty before it expires this summer!
No.
Yep-Retired
Yep-Retired
Gilmer TX
Thank you, but how does that have anything do with the fans turning on 30 minutes after the motor has been turned off? It is definitely those fans, no doubt about it.
BlueStangGT
Oklahoma
If it is indeed the radiator fans then I'd look for a sketchy sensor to be the culprit.
Yep-Retired
Yep-Retired
Gilmer TX
Thanks... I also found what appears to be the same or similar issue on an F-150 forum. One person's solution had to do with overfilling freon. Another's was to do with radiator being low. And another's was that they had inadvertently mixed types of coolant/antifreeze and so flushing and refilling with proper type fixed their issue.
So I have lots of stuff to check now and I appreciate the help the posters to this thread have offered.
