aburk1978
Hello, new to the site. I just bought a 2001 EB 5.4 with 158K. I was driving it home from Indy the day I got it (as is of course), and it started running rough when I applied a bit more accelerator while cruising around 70 mph. Started reading about it on this forum and figured it was a bad COP. Next day it finally threw a code, so I took it to Advanced for a free scan and it came up P0301 Cyl #1 misfire; Bank 1 and bank 2 lean (forget code #'s on that) and something about battery voltage, although no problems starting or holding a charge or anything. So, today I was reading that you can check if the coil is bad by unplugging it while the engine is running. So, I did that on #1 and it ran much worse (was idling ok at the time). I thought I had read that if the coil was bad, it wouldn't make any difference when I unplugged it??? Also, I was having trouble unplugging the connector on top of the coil on #1, so I tried on #4 which was a little easier to get to, and the locking tab broke off so it just pushes back on now but wont "click" into place. Am I going to need to replace that plug and, if so, how big of a PITA is that gonna be? People on here have mentioed replacing coils, plugs, AND wires??? Are the wire on top of the coils what they are referring to, since there are no traditional "plug" wires???? I'm freaking out a little because I just bought this thing 2 days ago, and I'm not sure I want to touch this thing now. Any help would be GREATLY appreciated!!! Thanks in advance!!!
Drove probably 40 miles or so and the SES light came back on (thought I might get out of the lean issue as well). So, I guess its the 90 elbow in the back to look at next. Could it also be an O2 sensor? What other vacuum lines besides the elbow at the back of the intake could it be? At least its not jumping and hesitating anymore! Making some progress I think! Thanks everyone!
