Kenny Brown
My 97 rear air ride leaks in the winter below 28deg. I have replaced everything and it still does the same. It does not have ride leveling. It has an aftermarket valve switch and gauge on the dash. To top it off, the pump freezes. I replaced and relocated the pump to the boomer compartment... It still freezes. I have to pump up the bags manually through the aftermarket valve stem located in the jack compartment. Anyone have an idea to how I can keep them from leaking out when below 28deg? Or, how to keep the pump from freezing? I was thinking of adding air shocks to keep the back up over night.
