Help no front brakes
slprell
arizona
I just got a 99 eddie bauer edition expedition everything was great had to replace the master cylinder bout a week later brake pedal is going to the floor started to bleed the brakes back went fine went to do fronts pumped up the brakes cracked bleeder nothing on either side anyone have a clue whats goin on. thanks
stamp11127
Temple, Georgia
Crack the bracket line to the caliper where it meets the hard line from the abs unit. If you have fluid there and it pumps out when the brake pedal is pressed, you have swollen/plugged rubber brake lines.
S
slprell
arizona
Still no front brakes
No fluid where hard line meets rubber line have pressure going into the pump none coming out abs fuse is good replaced abs module still nothing
