Have a 2000 EB Expo w Mach Stereo..Replaced it with an N3 nav system and CD changer, installation went OK except I can't get the speed sensor to work. OEM harness had 3 connectors one of which has speed sensor lead on it, used for increasing OEM radio volume as truck speed increased. OEM connector had grey/blk speed sensor wire to it and I tapped into it for speed input to nav system. This OEM connector is not used on new harness adapter installation. When I turn on nav system msg states speed sensor not connected and I'm locked out of all the options that are not available when vehicle in motion...like just about everything, can't even change the time. Manual states that the parking brake input relies on proper speed sensor connection also???? I hooked a +12v lead through a switch to the parking brake input so I could trouble shoot system, no I'm not going to watch DVD's while driving....I wanted the option of passenger to be able to program nav system while car in motion .. When I scroll through hardware set-up, one of few menues I can access, it lists hardware connections and shows speed sensor not hooked up and parking brake is always off, regardless of switch position. Also shows backup conncection fluctuating between high and low which manual says is normal, but it shows that even with the back-up lights off...which is what I tapped into for input...I called Crutchfield tech support and they couldn't help. Appreciate any suggestions or info. I do have access for wiring diagrams from alldatadiy.com, but I have found a few errors in some of their diagrams.
Thanks,
Yank
Thanks,
Yank
