help
cliff
Franklin, TN
i went mudding recently in my 2000 expy, and when i got back on the road i noticed it was only shifting at high rpm, it won't go into 4th gear or over drive, and my over drive light started flashing.
daoud el-massri
ct
I am sorry to hear that I used to do a lot of ridge running in west Virginia back in the 80 Wane County Pipe line . Ok to the subject at hand dran the trans fluid change filter as u drain it check for metal fragment if non install new fluid and filter . If that dose not work time for a trans good luck .
