Help!!
LMJPolasek
La Porte
I have had water leaking into the passenger floorboard soaking the carpet and anything setting there. I took it to the dealership to have it looked at and they are claiming that the expansion valve has gone bad and that is the cause of the leak however, the air is cooling perfectly. Has anyone ever heard of anything like this?
Blessings,
LMJPolasek
2017 Ford Expedition XLT 4X4
riphip
Memphis, TN.
Drain may be stopped up. Look under floorboard (under truck passenger side) to the right of the exhaust. You will see a little black hole about 1/4-3/8" diameter. If you have a wet/dry vac, try drawing the sludge out of that little drain.
No pictures or use your Google-foo for A/C drain and year/model of your Expy
